Old 09-21-2007, 04:17 PM   #1
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default I am so confused!!!!!!!!!!!!!!!!!
I thought this was the new and improved NHRA that is now dedicated to Safety & Sportsman Racing?
I am not sure that NHRA motives are pure and that they advance our sport??
I have no problem with the sport of drag racing changing, but I do have a problem when the NHRA doesn't give a reason for the change.
What is the benefit to the competitors for combining the fuel injected cars with the non-fuel injected??
Why is NHRA doing this and what is the expected outcome of this change?
What is the benefit to the competitors for combining the stick & auto class??
NHRA will never, I repeat never get the calculations right that will give an equal opportunity for sticks and autos in the same class heads-up.
What do you give to an A/SA that races an A/S or a U/SA Powerglide vs. the same combo with a 4 speed??
Has NHRA started a wildfire with the racers to conceal their real motives??
I asked this before and NEVER gotten a response from NHRA:
What is the 1 week plan??
What is the 1 month plan??
What is the 1 year plan??
What is the 5 year plan??
They know, they are just not telling us.
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 09-21-2007, 05:11 PM   #2
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
Default Re: I am so confused!!!!!!!!!!!!!!!!!
I got this from Len yesterday when I asked why:
Regarding class consolidation, many racers want more heads-up class racing and feel NHRA should let the system work as it was designed, based on weight to horsepower regardless of the type of induction system. This could also be the future direction with front wheel drive classes as well. Also, this move reduces the amount of classes by 26 which helps the contingency sponsor program. Contingency sponsors budgets keep getting pushed and stretched in many directions and we must do what we can to continue to keep them interested in NHRA class racing. As many agree, there are way too many classes in NHRA Stock and Super Stock Eliminator categories and we must continue to look at ways to reduce the overall number of classes.
Old 09-21-2007, 05:22 PM   #3
Ray Menard
Ray Menard's Avatar
My input...
I refer to Nitro Joe's stats and see the following:
Total active NHRA S/S cars in the country - 920
# NHRA S/S Classes - 92
Classes with less than 5 active cars - 41 (45%)
Classes with more than 25 active cars - 15 (16%)
At Dallas Nationals this weekend, 56 S/S cars have made their 1st qualifying pass.
20 classes had only 1 car and only 13 classes had 2 or more cars.
If we're not careful, we have 920 classes (one for each active car in the country!
Ray Menard
SS/CS (SS/DM & SS/EM)
#7386
Ray Menard is offline   Reply With Quote
Old 09-21-2007, 06:57 PM   #4
Bob Mulry
Bob Mulry's Avatar
Hi Ray,
I know one way to have more heads up races without changing a thing.
How about NHRA puts a realistic quota in place, so lets see what we have at Ennis.
How about we use your number of 92 for total S/S classes.
The quota is 70 cars and I think that will not result in many heads up races.
I think that I might see the problem, because all we have to do is look a little deeper.
So now we lump the fuel injected and non-fuel injected cars together, but we reduce the quotas.
The result is that we have to consolidate more, so we put the sticks & autos together, reduce the quota and guess what?????
We still have a problem so lets put S/S & Stock together and see what happens?
I can see the future and it's very dark.
NHRA thinks that we are too stupid to take the action that's needed to save sportsman racing.
Same old NHRA, same old racers.
I think the only plan that NHRA has is to get us fighting amongst ourselves so we will leave NHRA alone.
Does NHRA have a growth plan for the sportsmen??
We all thought that the sportsmen would be better off without the PROs, what a joke.
Will NHRA having no plan they can have a solution.
They just use crisis management to resolve ALL of the issues of sportsmen racing.
NHRA never came out in public with the reasons for these changes, I mean the real reason, and not what NHRA wants you to believe.
Bob
PS:
If NHRA put half the effort into expanding stock as they put into reducing it the outcome might be different?????
AND
A PS FOR RAY:
What was the total car count for active S/S racers in:
2006????
2005????
2004????
2003????
2002????
2001????
is it getting better or worse????
Is the plan working?????
Bob Mulry 7516 STK
A & M Motorsports
Old 09-21-2007, 07:50 PM   #5
Trevor Weiss
Right on Bob, I would say you have hit the nail's on the head. I have this to say, in the past when NHRA has given us enhancements every one was screaming. So NHRA has been watching and found a better way and that is to make the RACER'S enhance the RACER'S which goes along with what you said and that is to get racer's fighting each other while they seceretly go forward with no heat on them to the next enhancement.
I am also going to add this in this post. This is my opinion, by eliminating 2-steps from stock there is what I feel is going to be some what of a saftey issue with the stick cars. If you end up with no way to control starting line RPM you may be hitting the high end rev limiter, in my case over 7500rpm there is going to be alot of stress on parts that you did not have before so you may end up blowing engines, rear ends, trannsmissions and so on. I personally do not want to do any of that at any point on the track and then get fined for oil downs! If you are putting more stress on the rear end for example and it does not break on the starting line but rather it blows further down track and locks up or what ever the chances are pretty good that it may end up getting very ugly for you and maybe the guy in the other lane as well. As for the idea of flashing with a stick that is stupid, with my combo it is built to run above 5000rpm so to leave by flashing I will be slower and with the drop of 2 tenths on the index's that is just stupid again. I think the elimination of 2-steps is a giant ball of CRAP! With all of this crap these last two races in Div. 2 Atlanta and Reynolds may be my last if I can not come up with a leagal way to control the starting line rpm. So keep on taking away and there wont be any one left but the Fletchers,Biondos, Zanes ect. And Yes I know most of this did not belong on this thread. I just feel there are other fish to fry then the 2-step issue. Trevor Weiss B/S 2891
Trevor Weiss is offline   Reply With Quote
Old 09-21-2007, 11:19 PM   #6
Rory McNeil
I find it odd that NHRA wants to reduce the number of classes in Stock, yet every time you turn around, they are adding ANOTHER class to Comp Eliminator, which normally has considerably less car count at a NHRA race han Stock or SS. First NHRA dropped the Stock truck classes, now the FI classes, talk of stick and automatics combined,...(even though in recent years they seperated the sticks from the auomatics in Comp). In S/S, they seem OK with S/S as well as GT trucks, Modified Stock, Modified S/S, the MX classes as well as the GT and "traditional" S/S classes, yet I haven`t heard any talk of thinning the herds in S/S or Comp. Maybe they want t make more room for the "Sport Compact" revolution!
NHRA 6390 STK
M/S 85 Mustang
Old 09-22-2007, 11:38 AM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Exclamation Re: I am so confused!!!!!!!!!!!!!!!!!
No Rory, FIRST NHRA dropped the FWD classes! You people seem to forget all about us. THEY DROPPED US! Only with a year of begging and dealing mostly with people who have no idea what a race track looks like, we wound up with 4 classes total. Autos and sticks together and huge weight breaks. We had 16 classes, now we have 5. This cut our car count in half. Your next!!!
Old 09-22-2007, 12:38 PM   #8
Lynn A McCarty
Lynn A McCarty's Avatar
AHFS will never get it right because it is a flawed system by design. It artificially keeps the fast cars on the top with no hope for change. Do you realize how fast a combo must be to average with a six-sigma spread a second under? This means there must be an equal distribution of cars ABOVE and below the average. Of course this does not include sandbagging further exacerbating the average.
A class in high school statistics would solve the problem. Otherwise just like Bob pointied out the fuel injected cars will always be on top along with all the other bogus combos in S/SS. It is either purposely designed that way, or vastly applied unscientific methods to mask as a scientific event.
Racers need to stand up and get it changed. It isnt that difficult to do it better. I think it is better than doing nothing, especially if people are at the throttle, but not by much. I am sure we have the knowledge to put fuel injected cars back in, but AHFS will not do it.
Lynn
Lynn A McCarty is offline   Reply With Quote
