Old 10-06-2018, 11:16 AM   #1
John Cannata
Liked 6 Times in 3 Posts
Default Ford 460 Super Stock Engine
1974 220hp NHRA rated at 300hp
Set NHRA National Record at 1.05 under the index in 2013
D3VE-A2A Cylinder heads done by Jacques Blais
Victor intake port matched to heads
Wilson spacer to Thermoquad carb
Custom Comp roller cam
Crower lifters, Jessel rockers, 7/16 double taper pushrods
Danny Bee Belt Drive
Manley valves, PAC springs
Block 460 + .040 partially filled
Block has roller cam bearings and bronze lifter bushings
Eagle rods with JE pistons
ATI damper, MSD crank trigger, MSD billet distributor
Custom aluminum Moroso oil pan
ATI flex plate, Tilton starter, Meziere water pump, sheet metal valve covers
This engine was run this year at the Atco National Open and Maple Grove Points meet.
Dyno and Flow sheets available for the buyer
Asking $15,000
Have lots of spare and extra parts also for sale
Contact: John 860-918-2524
John Cannata is online now   Reply With Quote
