Old 03-06-2018, 12:29 PM   #1
fastlane
Liked 53 Times in 20 Posts
Default Beadlock Conversion
Has anyone had any experience with converting there wheels to beadlocks there are single and double conversions available. I know it adds weight but not that much they have it down to about 3.3 lbs per single lock. The tire has moved about 1 inch in 1-2 events
fastlane is offline   Reply With Quote
Old 03-06-2018, 01:29 PM   #2
topless63
Default Re: Beadlock Conversion
Weld Wheel did me Magnums. quick turnaround
topless63 is offline   Reply With Quote
Old 03-06-2018, 02:25 PM   #3
Ed Wright
Ed Wright's Avatar
I always put a mark on the tires by the valve stem. Mine have always moved some at first. Have always stopped moving by the second race. Tubeless, 13 psi. Learned to not lube beads when mounting. Just mount dry.
Ed Wright 4156 SS/JA
Old 03-06-2018, 05:18 PM   #4
TOSTO RACING
TOSTO RACING's Avatar
Liked 665 Times in 187 Posts
Champion Beadlock does good work and they are fast! I've never seen one move on a single Beadlock yet .
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 03-06-2018, 07:26 PM   #5
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Beadlock Conversion
Holeshot Wheels in Bunnell, FL does their own as well as other brands.
https://holeshotwheels.com/collections/beadlocks
My tires have moved also, but less over time. I also swap them side-to-side after every race to minimize any change in balance and tread wear.
LOCOMOTION Racing
Old 03-08-2018, 03:02 AM   #6
Adger Smith
Liked 880 Times in 311 Posts
Frank Parks does it, too!
Adger Smith (Former SS)
Old 03-08-2018, 11:15 AM   #7
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
What's the difference between single and double?
Floyd Staggs 787 SST
Old 03-08-2018, 11:45 AM   #8
fastlane
Single is just the front of the wheel double is both sides.
Old 03-08-2018, 12:36 PM   #9
Floyd Staggs
I know that but is there any difference in the way they perform? Do you need the clamping on both sides? I've always used screws but I just got new wheels and I don't want to drill them.
Old 03-08-2018, 06:11 PM   #10
TOSTO RACING
On my last set from Larry Hodge we bead locked the front and knurled the rear so they won't go anywhere. I don't see any way the back can move on a single ,but I'm not running the horsepower to worry about it. Big hp guys probably need double's.
5664 GHI/SA
