Old 03-25-2018, 04:05 PM   #1
Tarzan Racing
Liked 2 Times in 2 Posts
Default Shocks
Need input on what is the best way to figure out the proper length coil over shock for a ladder bar car. only backhalfed it over 20 years ago, better late than never.
CONFUSED
Tarzan Racing is offline   Reply With Quote
Old 03-25-2018, 05:31 PM   #2
Hacksaw
Liked 312 Times in 175 Posts
Default Re: Shocks
Set the car at ride height, measure the center to center of your shock mounting points, pick a shock with a min. of 5" travel and have that shock mount close to the center of it's stroke.
Old 03-26-2018, 06:47 AM   #3
Tarzan Racing
Default Re: Shocks
Thanks for the info
Old 03-27-2018, 11:25 AM   #4
Tarzan Racing
Default Re: Coil Over Springs
any suggestions on spring rate for 2900 lb car
Old 03-27-2018, 01:53 PM   #5
Hacksaw
Default Re: Shocks
130 lbs. IMO You only want enough spring to hold up the rear of the car
Old 03-27-2018, 04:52 PM   #6
Tarzan Racing
Default Re: Shocks
Thank You again LOL
Old 03-30-2018, 04:17 PM   #7
JimmyStack149K
JimmyStack149K's Avatar
Default Re: Shocks
Hey Frank,
Don went to double adjustables a couple of years ago but i cant remember the brand. Anyways, they told him to ise the lightest spring theat will hold the car up. I believe he had 130s in it maybe even heavier and it was preventing the suspension from working properly. You can call him and ask to make sure.
JimmyStack149K is offline   Reply With Quote
Old 03-30-2018, 05:39 PM   #8
Tarzan Racing
Default Re: Shocks
Thanks Jim
I will give him a call
Old 03-31-2018, 08:29 AM   #9
SG192L
Default Re: Shocks
Frank I have been running 110lbs on the back of mine for years
SG192L is offline   Reply With Quote
Old 04-01-2018, 06:51 AM   #10
Tarzan Racing
Default Re: Shocks
I'm finding that between 110 and 130 is the magic number. I have 130 springs, will get 110 with new shocks, and start testing. Now I have a starting point.
Thanks for the help
