Old 09-28-2007, 09:54 AM   #1
Ronnie Smith Jr
Ronnie Smith Jr's Avatar
Default Valvetrain Componets
The below listed valvetrain componets are available. Discount for bulk purchasing. All items priced do not include shipping.
Jesel, rocker, part #CABL90, 1.9 ratio, no offset, new, $60
Jesel, rocker, part #CABR90, 1.9 ratio, no offset, new, $60
Jesel, rocker, part #CLFR80, 1.8 ratio, .300 offset, new, $60
Jesel, rocker, part #CLFL80, 1.8 ratio, .300 offset, new, $60
Jesel, rocker, part #CAAS70, 1.7 ratio, no offset, dyno time only, $45
Jesel, rocker, part #CAAS60, 1.6 ratio, no offset, dyno time only, $45
Jesel, part #KRS-28100, SBC shim kit, new in package $30
Jesel, part #TOL 29351, 11/32 standard height gauge, new in package $20
Jesel, rocker mount shafts, (3), new out of package $20 each
Jesel, screw cups, (7), new out of package $100 pack
Jesel, rocker bearing/trunions (5), new in package $15
Jesel, bearing/trunion snap lock rings (7), new $7
Comp Cams, part #611-16, 11/32 super lock, hardened steel, new in package $17
Comp Cams, radial 11/32 lock, hardened steel, new in package $20
Comp Cams, part#890C-1, roller lifter, (1), no offset (840 dia), new in package $20
Comp Cams, part #894C-1, roller lifters, (2), with offset (875 dia), new in package $20 each
Comp Cams, lifter link bars, (8) new in package $50
Comp Cams, lifter link bars, (7) new open package $30
Comp Cams, part #8905, pushrods, 7.750 length, 3/8 080 wall, 4 new, 1 used $40
Comp Cams, part #7913, pushrods, 3/8 080 wall, 7.800 length, 6 new, 5 used $70
Comp Cams pushrods, 7.750 length, double taper, 125 wall, 10 used $70
Comp Cams, used (dyno) springs (4 sets), part # 086
Powerhouse/Comp Cams, part #101215, pushrod length checker, 6.8-7.8, new in package $17
Powerhouse/Comp Cams, part #101220, pushrod length checker, 7.8-8.8, new in package $17
Powerhouse, part #102114, stainless steel bung/plug kit, new in package $6
Powerhouse, part #301090, spark plug index washers, new in package $10
Powerhouse, part #301020, 14mm air hold fitting, new in package $5
Mr. Gasket, part #5812, sbc intake gaskets, new in package $17
Mr. Gasket, part# 102 or 102G, sbc intake gaskets, new in package $8
Mr. Gasket, part #106, sbc intake gaskets, new in package $10
Mr. Gasket, part #976, hex head header bolts, 5/16-18x3/4? 14 count, new in package $6
Mr. Gasket, part #917, hex head header bolts, 3/8-16x1? 12 count, new in package $7
Mr. Gasket, part # 5425, baffled grommets, fits 1 ? ID hole, new in package $5
Manley Valves, 8, used (spare), 5.100 long, $75
Manley, part #13161, hardened steel locks (16), 10 degree standard, new in package $25
Ferrea, part #K10053, 11/32 standard radial titanium lock, 10 degree, new in package $100
Ferrea, part #E11016, titanium retainers, 10 degree (16), new in package $325
Fel-Pro, part # 1628, valve cover gaskets, (2), blue molded steel core, new in package $40 each
B&B pushrods, 7.750 length, 3/8, 080 wall, 6 new $40
CSR billet aluminum valve cover grommets, pair, new out of package $30
Header bolts, 12 point head, 5/16-18x3/4?, new in package $6
Misc set of 10 degree, 11/32 standard, valve locks, new out of package $10
Ronnie Smith, Jr.
ssia1072@yahoo.com
646/957-2416 cell
Ronnie Smith Jr is offline   Reply With Quote
Old 10-07-2007, 10:25 PM   #2
Ronnie Smith Jr
Default Re: Valvetrain Componets
ttt
Old 10-29-2007, 04:30 PM   #3
Ronnie Smith Jr
End of the season sale. All parts and equipment must go. Don't delay...
