Liked 42 Times in 17 Posts
What are the stipulations on steering dampers, specifically on a 3rd gen Camaro? Stock and/or super stock. Getting some nasty tire shimmy on the landing.
Liked 1,951 Times in 590 Posts
Ed Quay has a nice kit for that car. Typically if you have shimmy something is loose. I had the same issue on my gen 1 Camaro. Turned out the top bolts on the steering box were loose. Check to make sure everything in the steering system is tight and no slop
Mike Pearson 2485 SS |
Thanks Mike, I saw that damper but is it legal in stock/super stock? I'm pretty vigilant on checking the car over between runs, keeps my mind busy.
Liked 8,124 Times in 1,534 Posts
Almost all 3rd gen camaros run that ed quay piece, actually an early VW absorber...its legal and very important if you don't want to shake the fillings out of your teeth....
Thats the million dollar answer I was looking for, thanks!!
Liked 133 Times in 76 Posts
Just about every S or SS 3rd gen has one, the others will have one if they wheelstand. As stated there is a problem on those cars cracking the frame behind the steering box and the frame rails flexing. There is actually a factory piece and it's sold aftermarket also that ties the L and R rails with a bar between the sway bar mounts to stop flex.
