Old 02-23-2017, 09:55 PM   #1
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Default Parts for sale
-327 041 Super Stock heads by Heads up!, One head was brand new just done last winter and has less than 50 passes on it paid over $2400 for just the porting & assembly work on this one head, the other is older and has a leak in one intake bowl. 2-heads with valves, springs, retainers. No rockers. I also have another bare head that is matched to these ones that also has a leak. $3,000 for all.
-Used Auto Meter 17 channel data logger. Includes software, 50' download cable, dual axis accelerometer, engine rpm, input shaft rpm sensors, driveshaft rpm with collar for 9" ford rear end, oil pressure with sender, fuel pressure with sender, and 4egt used sensors and 4 older used sensors (2 of the sensors last used were not reading correctly and need to be swapped or replaced), I have the instruction manual, a box of misc extra sensors, pickups, wire extensions and connectors. $450
-M/T 3056 st 29.5x9 stocker stick tires, about 50 runs on the pair $125.00
-Port-A-Tree Eliminator 2000 plus with two hand held buttons and power cord $125.00
-Jegs / Gforce black SFi 3.2A-5 jacket and pants both XL $100.00
-Autometer 5332 Shift light in original box used once. $50.00
-4 qts Redline oil MT-90 manual transmission Gear oil $30.00 for all.
-SBC 327/250 pistons JE job #580450 8 pistons used and coated / 3 pistons new uncoated. 4.032 bore / .875 pin 2.500 long / .043-.043-3.0mm oil ring. Bare piston weight 412 grams $375
-SBC Block castings $150 each
283 3789935 date A43
283 3789935 date B153
327 3782870 date I254 (Marine grade block)
327 3782870 date I214 (Marine grade block)
Call text or email for more information or pics.
(616)437-4958
brad@zaskowskibuilders.com
Thanks
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is online now   Reply With Quote
