Liked 7 Times in 6 Posts
I footbrake in a 6.50 index class that uses a .400 tree. To get decent lights, I have to deep stage. This works really well as long as the starter doesn't send the tree the instant I put out the top bulb. I made 4 passes on Saturday and my worst light was .021 because he gave me time. On the 5th pass he sent the tree as soon as I put out the top bulb. I was .240. Will a transbrake allow me to stage light? Will a 2 step? I'm running a 400 trans but seriously thinking about going to a glide.
Liked 704 Times in 203 Posts
Ron, there are 2 reaction times involved in leaving the line. The drivers reaction to the light on the tree and the cars reaction to the input from the throttle, trans brake etc. If your car is slow changing the transmission may not help much. A two step or trans brake may help slightly with the increased rpm over the foot brake method but until you get the car set up to cut a good light the best driver in the world may always be late on a pro tree. There are plenty of places to look to improve the cars reaction time. I would start with optimizing what you have and then make the changes needed for improvement. My vote would be to go to a tran brake and then start the sorting out process all over again, you may soon need a delay box.
Good luck |
I should have posted this in the tech section. Thanks Mike. It's been a long time since I tried to stage light with a .400 tree, but I think my lights were .075-.095.
Liked 431 Times in 224 Posts
Very few 6.50 door cars will be able to go .000 on a .400 Pro tree.
I think you would be a little quicker with a transbrake/2-Step setup with a Pro Tree transbrake, but you'd still be in the .040-.050s at best. Most of the Super Gas guys run some combination of aggressive chassis setups, small front tires, and front travel limiters to cut a light. And that is likely launching with a lot less weight and more power than you have.
S/ST 51 S/C 53 |
#5 | |
Mike Gray's advice is spot on.
You might also look into a device Called a "Bump Box" which will allow you to roll in deeper while keeping the top bulb lit. (If the blue light is on) Note this device is only NHRA legal for Pro-Mod so check with your local track before you consider buying one.
Bill Baer 3391 SC, 339B SC, QR Last edited by Bill Baer; 06-15-2016 at 12:00 PM. Reason: More info |
I softened the rear shocks and the car hooks better so I'm going to adjust the front shocks to limit travel. I can see that I'm running a little too much air in the slicks too. But I guess no matter what I do I won't be able to get .00 lights by footbraking. Maybe if I had a really loose converter or more gear.
you could try leaving a couple hundred rpm higher
http://classracer.com/classforum/showthread.php?t=57448
I thought we had tried this before.... guess we don't know what we are talking about
Liked 552 Times in 215 Posts
I footbraked in S/ST on a .400 tree in the early 80's....Deep staging not allowed by then...
69 Camaro....small block...PG.... I had an ATI treemaster 8" converter and could stall it to 5000 or even a little higher.... Could get maybe .460 RT at best.....without rolling in some.... Biggest RT improver....LIMIT FRONT END TRAVEL....but you will spin the tires once you go to far...been there done that... There were a few cars and guys that could get decent RT's shallow staged footbraking but they refined their cars and probably staged as deep as they could without knocking the top light out.....
