Liked 4 Times in 3 Posts
Ive been bracket racing a long time and been in super street for about 10 years. I usually race atleast 3 divisional races a year. Unfortunately I dont do much else do to time constraints ,track closures etc. Ive never been very good at being the slow car even in s st where the cars are usually not much more than 10 mph faster than I am "138" I have a hard time judging closure rates and making myself peddle the car. I usually do pretty fair because I have a good handle on my car but im getting tired of breaking out when the car speeds up more than I think once in awhile and taking 10 ft of stripe. Do you guys have any tips or resource suggestions they may help me be less of a dumbass
I don't run it anymore but when I did I was in the 125-128 neighborhood and liked being the slower car. Look at it this way, you have the first opportunity to get there. Even now I run I/SA and 90% of the time I am the slower car. It always helps to know what you are running ET wise but the best advise I ever got was you cant be afraid of giving up the stripe every once in a while in order to make it tight. One other thing I always try to do is before the run is familiarize myself with my opponent's mph and where I think they should be in any given moment on the track compared to me during the run. In other words how the run should play out in my head before the race ever actually happens. Good luck.
#3 | |
Liked 1,986 Times in 599 Posts
Mike Pearson 2485 SS |
Thanks for the responses. I need to just keep at it. I really dont race enough anymore. 4 or 5 times a year. It seems like once I run one tight race im fine. Next month or 2 ill do the same dumb stuff
Liked 21 Times in 7 Posts
I have raced a car that would be chased 9 out of 10 runs with some success. Try setting up for a 10.88-10.87 and start getting used to scrubbing off E.T. Do it in time trials every run. Know in eliminations that you will be on the brakes. It's a critical skill to develop if you ever want to win regularly. Also, I highly suggest putting a data recorder on your car. Consistency is crucial, and the top guys usually have the most consistent race cars.
#6 | |
Liked 431 Times in 224 Posts
Yes, you will screw it up. My saying is, if you don't give it back once in awhile then you aren't making it tight enough! Same philosophy as having the occasional red light; it is going to happen if you are being aggressive enough to win. Tony Leonard |
You simply must master spot-dropping to win regularly in a slower Super class car. It's an absurdly simple, yet effective technique to do more with less. Once you get mentally used to the idea that you will always drop, and just vary the spot, you will hit and miss the dial in the same as before, but gain the crucial advantage of surprise against the opponent. The good ones will know to catch your drop, but they won't know when it's coming, and will make far more mistakes than if you give them a "clean wheel".
