Old 10-07-2014, 05:56 AM   #1
Rich Concato
Default Koni Electric Shocks with Air Sweeps
1 set Koni Dbl. Adjustable Electric Shocks
Valved by Don Ness.
GMM Air sweeps (Ness) w/ Ness timers
Ness 3 stage "yellow" controller (rare)
Air regulator
Air Lines
All you need to do is install and watch your 60' times drop.
1 468" BBC Bracket Race Engine
4 License Passes sine new!!
Brandywine Aluminum Heads
Eagle Crank & Rods - ARP 2000 Bolts
Jesel Rockers, Belt Drive, & Distributor
Dry Sump Oil System
Moroso Aluminum Pan
Reher-Morison Edelbrock Manifold
Sold With or without BRE Dominator
$8000 Carb to Oil Pan w/starter
$7500 Minus Carb w/starter
Will dyno if you want.
1 New Dedenbear timer for A1 Lock-up - $160.00
1 set of 2.080 PRC dominators - $1500.00
Aluminum/Copper battery cable 1/2 the weight of copper!!! - Call
Many Lithium batteries - Call
Many ARC Switch panels - Call
Prices do not include the trip.
Questions please call or email.
Rich@ConcatoRacing.com
732-580-6875
Rich Concato is offline   Reply With Quote
Old 10-21-2014, 02:34 PM   #2
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Default Re: Koni Electric Shocks with Air Sweeps
Sent you a PM, hoping you can help.
sst7250 is offline   Reply With Quote
