Old 02-28-2014, 10:48 AM   #1
Dave Gantz
Liked 251 Times in 125 Posts
Default Flywheel Material
Years ago, generally, different weight steel flywheels were used for launching a drag car. Aluminum flywheels were used for circle track cars, to accelerate quicker, not having to worry about the launch. (At least that's the way I always had heard it.)
Are aluminum flywheels used in drag racing these days? (Or before?) I see a lot of them for sale, and with the advent of adjustable clutches, I was wondering if maybe the combination of aluminum flywheel and adjustable clutch (base and centrifugal) has changed things.
Old 02-28-2014, 11:10 AM   #2
tj310
Default Re: Flywheel Material
http://www.advancedclutches.com/metalcoverclutches.htm This is a link to pictures that show the extent that they go to to reduce flywheel weight. ---Trevor
Old 02-28-2014, 02:56 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,958 Times in 593 Posts
Back when I ran a stick in my car which was before all of the good clutches of today the difference from a 14 lb aluminum flywheel with a steel face to a 25 lb steel wheel was 2 tenths. This was in SS/J. Back to back tests on the same day. Many moons ago though!!
Mike Pearson 2485 SS
Old 02-28-2014, 03:08 PM   #4
older racer
Liked 68 Times in 26 Posts
hi, BINGO, had same results also. lw is faster, simple physics!! same holds true today.
older racer is offline   Reply With Quote
Old 02-28-2014, 08:43 PM   #5
randy wilson
Liked 22 Times in 22 Posts
Most people say the aluminum is faster, and I'm sure in most cases it is, but in our SS\CS 291 c.i., 6.50 rear, 3.29 low, a rag street strip clutch, and a 30 lb. fly wheel was .06 quicker back to back, then a soft lock, and aluminum 12 lb. flywheel. I know, it surprised me, but then maybe we had the wrong tires, or something.
don,t have one
Old 03-01-2014, 12:04 AM   #6
b.guggenmos
b.guggenmos's Avatar
Liked 3 Times in 1 Post
There used to be an old rule of thumb that said flywheel weight should be 1% of the vehicle weight. But that was back in the day of a 2400 lb. pressure plates or the discs with four pucs. They bite hard and break parts. Brian
b.guggenmos is offline   Reply With Quote
Old 03-01-2014, 09:20 AM   #7
joespanova
Liked 13 Times in 11 Posts
Inertia. I went from a 30 lb steel wheel to an 15 lb aluminum and picked up roughly .15 or so. I'm sure there are application exceptions.....but generally everyone benefits from the lighter parts now a days. Faster recovery at the gear changes , clutchless transmissions , adjustable light weight clutches , data loggers .....all expensive stuff............but always the std. of fast "manual" or as I like to refer "semi manual" stick cars. The difference being , clutch assisted or clutchless.
I don't consider "clutchless" as a true "manual".
Old 03-01-2014, 09:48 AM   #8
james schaechter
We tried lighter back to back testing years ago and the heavier stuff was quicker. We finally stayed with the lighter pieces long enough to figure it out and it was much quicker than the heavy clutch flywheel parts ever were. I think the heavy stuff had an easier tuning window, but if you figure out how to use the lighter equipment, it is better all the way around. There is a learning curve. There are some real good choices out there for transmissions and clutches that were not around before. The clutches we run today in our stocker are waaay better than the stuff we had in our modified car in the 90's!
James Schaechter 3163 STK
Old 03-03-2014, 12:28 PM   #9
Dave Gantz
I guess the answer is, "It depends".
I like what you're saying, James. Gotta work on each and see what ends up fastest.
