Old 11-30-2013, 10:53 AM   #1
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Default quick question
Would anyone happen to know if the newer sealed Turbo Start batteries can be charged with the older style charger that was made for the acid style Turbo Start batteries?
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 11-30-2013, 12:14 PM   #2
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: quick question
Yes you can but you need to change a chip in them, if you tell them they will send it with the new battery.
Old 11-30-2013, 03:48 PM   #3
John Nechiporchik
Liked 13 Times in 7 Posts
Yes. You can google Turbo Start Batteries and find instructions to make the adjustment. It involves removing the cover and adjusting the potentiometers while attached to a fully charged 16 volt battery and using a voltmeter. Less than 10 minute job. I have done it on three different old style chargers and worked successfully every time. Instructions are very clear (including pictures!!).
John
John Nechiporchik is offline   Reply With Quote
Old 12-01-2013, 12:11 AM   #4
Angelo DiTocco
thanks
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
