Old 01-15-2014, 02:51 PM   #1
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Tires for tow vehicle
Well it's time for new tires for my F-350, what's best out there? Pulling 48 footer loaded up so don't want to really skimp on tires just would like some suggestions. Thanks Joe
Joe Buchanan SS/BX 3117
Old 01-15-2014, 03:14 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Default Re: Tires for tow vehicle
No contest, Michelins all the way. Had them on my Dually and was extremely satisfied with the ride, wear, quietness and load carrying capability.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-15-2014, 06:06 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,956 Times in 591 Posts
Over the years I had the best luck with Firestone. I also had some Dayton commercial tires that wore like iron. Never had any tire problems on the duallys that I have owned
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 01-15-2014, 06:42 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
I have Firestones on my dually with loaded 48 foot trailer. We haven't had any issues. We have been buying tires from Direct tire and having them shipped to the house for our other vehicles, we have been money ahead even after paying for the new tires to be mounted and balanced from a local tire store so keep that in mind.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 01-15-2014, 06:51 PM   #5
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
X2
Our F350 has a bit over 45k in the rears and they are less then 1/2 way there. They cost alot more but are worth every penny. Most other tires have been done at 45k.
I run the XPS TRAC and they can be retreaded.
http://www.michelintruck.com/micheli...ead=XPS%20TRAC
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 01-15-2014, 06:52 PM   #6
FED 387
Liked 334 Times in 181 Posts
I have BF Goodrich Commercial truck tires on mine--- reasonably priced/quiet/ long lasting/ good traction both wet/dry/snow---get about 70-75,000 on them then swap em out sell them to the Mexican landscapers--- by the way they were OEM on my Ford Super Duty so I had success with the original tires just kept using them--FED 387
Old 01-16-2014, 09:20 AM   #7
buzzinhalfdozen
This set was Michelin, have plenty of tread left but badly cracked on sidewalls. Ran original tires till tread was getting low round 5/32 never cracked on the sidewall like the michelins did. However my truck does sit outside but it always has. Was not happy with the sidewall cracking as it started after about 2 years and slowly got worse, not saying Michelins are out just a bit leary of them now. Thanks for the replies. Joe
Old 01-16-2014, 05:07 PM   #8
Run to Rund
Liked 54 Times in 27 Posts
My 2013 Ram 3500 came with Firestone Transforce HT and they have worked well so far.
Old 01-17-2014, 09:06 AM   #9
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Same experience I have had with Michelins.....
Old 01-24-2014, 10:18 AM   #10
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
How old were the tires when you installed them?
STK1217 is offline   Reply With Quote
