Liked 663 Times in 201 Posts
Had fun with this car. Ran it as a stock suspension 10.5 car.
Chrome Molly: Cage (funny car) drive shaft front K member upper & lower arms coil overs front & rear Ford 9" 4:56 Pro Gear Wheelie Bars & Parachute BG 400 fuel system MSD 72al ignition Wilwood disc brakes front & rear Motor: 638 Donovan Block Dart Heads Dart Intake Single 1250 Dominator Lunati ProMod Crank & rods 14.5 JE gas ported ceramic coated pistons Full Jesel valvetrain Transmission: Dedenbear Glide straight cut gears 1.96 first gear Coan Converter 9" 6600 stahl Car is untubbed with $18,000 multi colored show winning paint. Car has been 7.80's on skinney tire (10.5) at 3200 lbs. with another motor and will hook in sand box. Car goes straight and true. Comes with 2 hoods (1 cowl and 1 with scoop) both match the car. Car will re-certify to 8.50 and a couple of kidney bars and it will certify to 7.50. 638 only has 5 motor passes on motor since built new, NOS never activated. Car does have title, can be seen by appointment, can email photos. Will sell the following ways: Turnkey $44,500 OBO Rolling (I pull motor and trans you get everything else) $18,500 OBO Motor $24,000 OBO ($38,700 invested and have receipts) This would make a good T/S or T/D motor Glide with Converter $5,000 CASH IS KING, Need to move this car too as new car is coming. 832-264-2478 or email Nick@hoffpro.com Last edited by nickh; 11-13-2013 at 09:24 PM. |
