Liked 55 Times in 26 Posts
I have a 8.5 10 bolt in my nova.. No one makes a "pro" gear for a 10 bolt so I have always ran the street gears.. I have been debating selling the current rear and buying a 12 bolt but that is a huge expense even after selling the 10 bolt..
Who makes the best gear for a 10 bolt? Is it worth getting the gear treated or polished? ( I think Jim bailey used to do this as a business)... Just really hate to swap out the current rear end.. |
Liked 69 Times in 32 Posts
Dewco, their process really works a little spendy
But they last
Ron Mattson 5015 STK |
#3 | |
Liked 184 Times in 113 Posts
D |
I have moser axle and spool package in mine with motive gears. Motives are good for about 5 years in my car and it weighs around 3500 lbs with me in it.
Liked 56 Times in 27 Posts
Fleming ,
There are some people making PRO- gears for 8.5/10 bolts ... What gear do you need ???
Dave Ribeiro 1033 STK |
I have moser axles and spool in the car currently..
I am thinking 5.14 or 5.38 gear.. I just bracket race right now with 4.88.. if i fix a class motor it is a low hp 74 350 so I think a 5.14 with a 200 or turbo transmission with 2.75 low gear.. I may send it to innovators west and have gear lightened and treated if you guys think its worth the extra money.. I didnt know anyone made a pro gear so thats good news. |
Liked 719 Times in 220 Posts
There's no reason in the world that that 8.5 10 bolt wouldn't hold up in that car with a stocker 350 and an automatic.I seem to remember guys running them with a posi unit, that was the weak point. If you had a good set up, a good spool, quality axles, maybe steel web caps,etc. you probably won't ever break it. I don't think I'd use one in a '70 Chevelle A/S car, but the small block I,J or K car would have no issues. That rear end is probably 80-90% the strength of a 12 bolt anyway. Some of the bearings in it are the same as the 12 bolt uses.I do remember a shop that used to get junkyard big-car 12 bolt housings, cut the axle tubes off, and attach the axle tubes from 10 bolt Camaro-Nova rear ends to it. He had the jig to line things up, he was an excellent welder, and he had a good product, but he's been gone out of business for some time.I think big car 12 bolts have gotten scarce around here as well.Good luck with your project!
Liked 535 Times in 110 Posts
I've got a friend that has a pretty fast bracket car that has had really good luck with his 8.5" 10-bolt. The car, a '84 Hurst/Olds with a 455 Olds/Glide with a t-brake, runs 8.50's. The car is pretty light, under 2500 lbs., and he actually runs a street type gear.
Jim Kaekel 3836 STK |
Moser has an entire BOLT in REAR for under $2000.00
Just about as much as installing everything yourself... Dan Last edited by Dan Fahey; 11-01-2013 at 01:13 PM. |
Yeh I think I am good as well now that I think about it.. Right now the car runs 6.90's 1.45 60'.. I make a class car out of it I prob wont run 7.30's in the 1/8 but I would think the 60' would still be down in that range with the 2.75 low gear..
I will probably send the axles to moser to get them star flanged and gun drilled this winter.. and switch the pinion yoke over to a 1350 u joint.. ( I dont trust the 8.5 strap setup) Thanks fellas! |
