Liked 6 Times in 5 Posts
what are most super class racers using in the open cockpit super gas cars? getting air up under the front of helmet.using a neck collar-with a simpson bandit helmet. a lot of brands with a lip built into the front.just wanted a real racer opinion of what racers are using.
Liked 886 Times in 238 Posts
I'd try putting a windshield with a slightly higher lip in the center in front of the driver ,before changing helmets.
My windscreen is 1 1/2" higher in front of me , about 7" wide ,than the rest of the screen. Made a huge difference.
Liked 348 Times in 152 Posts
You might try a different style (wedge?) collar that supports the helmet better also.
Phil Molski PMR Performance S/C 1623 |
Should ask what body style you have .
'27-'37 bodies have the driver much more exposed to the air flow than Vette bodies. I know I could feel a difference on my Vette just from changing scoop styles.
63 corvette,but I think it's the location-setback-and roundness of the hood scoop that is directing the air back toward the drivers compartment.
#6 | |
I'd try raising the windscreen a little. a small increase in height or a small lip will make a big difference.
#7 | |
![]() After I bought a HANS I had to add a helmet skirt so now I get no air under the helmet and if the visor fogs,I have to try to crack open the visor slightly before staging to let a little air in. P.S. if it's fogging bad, I wait till the last possible moment to put the visor down and hold my breath till the car is down track ![]()
Bill Baer 3391 SC, 339B SC, QR Last edited by Bill Baer; 08-04-2013 at 10:04 PM. |
I have a 63 Vette roadster and was having issues with the wind trying to lift my other helmet off my head. It was a short Simpson carbon helmet. I went to a Simpson speedway shark with a front wickerbill. That made all the difference in the world! Of course getting used to the wind also helps, but the other helmet would have never worked in this car. Just way to short. I currently use a neck collar, but as soon as I remember to order a head sock I will be using my Hans.
Ryan Koener S/G 310C |
I have an Impact Draft. I got it because I was getting lift on my Simpson Super Bandit. It was unreal how big of a difference it made.
