SBC 380" Bore 4.080 X 3.625
ALL the best parts!!!!!! Polished Sheet Metal Valve Covers, Holley Carb 750 Holley Intake, Brodix Heads with Raised Intake Runners, Dell West Titanium Valves Intake and Exhaust Manley Valve Springs, Jesel Shaft Rockers, JE Gas Ported Coated Pistons, Brass Inserts on Lifter Bore, Comp Cam, Crower Crank, Crower 6" Rods, Bowtie Block, Moroso Comp Oil Pan, Mangus External Belt Drive Oil Pump. Additional Set of Manley Valve Springs. MSD Distributor Motor Makes 665HP @ 7200 RPM. 527 LBS Torque @ 5500 RPM. Runs 8.teens @ 164mph IN 1700lb Dragster on gas with no Throttle Stop. With Throttle Stop 8.90 @ 160mph VERY CONSISTENT and VERY RELIABLE !!!! Dyno Sheet Available. Invested ALOT more $$$$$$ than asking. Jethot Coated Dynatech Downswept Headers and Coan Converter also available. Asking $8500. O.B.O. for Motor Asking $9500. O.B.O. for Motor, Headers, Converter, Throttle Stop (TS-1) If you have any questions or want to see pics Call Don @ 401-474-8647 |
