Liked 203 Times in 52 Posts
New factory GM oil filter adapter with bolts(not Plugged) $20
New factory long starter bolts $5pr Moroso Lightweight BBC fuel pump rod $10 Moroso BBC valve cover hold downs (set)) $10 Q-jet to square bore intake adapter(with hardware) $10 BBC Crower Roller lifters Very low runs (#66291H-16) $300 Comp BBC Roller Lifter #897-16 (New In Box) $300 Mallory # 28880 Coil $75 MSD RPM Chips 8,83 & 9000 rpm $25 MSD 6AL box to dist cable (NEW) $10 BBC Victor Head Gaskets $50 pr Q-Jet Billet Spacer( Faith Air) $150 Richmond 9inch gear (5.29) $200 Tranny Sheild TH-350 $75 Merge Collectors -22 inch long 2 1/8 primary pipe 3 to 4 inch merge $200 Merge collectors-19 inch long 2 1/8 primary pipe 3 1/2 to 3 ¾ $200 Dynomax Race Bullet Header Mufflers 2 1/8 primary pipe $200 JAZZ clear Fuel Jug $20 Moroso solid core BBC wires. (Sleeved and heat shrinked ) $125 ATI Suoer F tranny fluid $75 case Joe Gibbs XP1 5w/20 oil $200 case |
PM sent. :-)
Steve Obertanec |
