Liked 336 Times in 183 Posts
ALL PARTS ARE PLUS SHIPPING!!! Many of these parts were either spares or for projects we changed our mind on.
1 Each used Reactor 168 tooth flexplate internal balance fits Chevy- good condition--$75.00 1 -Each used MSD 8251 coil--$50.00 1- Each NEW in the box MSD 8261---$120.00 1--Each used CSR Turbo 350-400 Alum tran shield Blue powdercoated ---$50.00 2 --Each--used Chevy SFI flexplate shields--$25.00 each 1--Each-- Hughes Powerglide trans shield--$50.00 several ATI balancer shells and one complete balancer SBC snout shell is faded, plus one balancer MINUS the hub really great condition--- really enough parts to make probably 2 good balancers out of it ---ALL are 6 3/8 inch diameter---$200 for the lot 1--each --WELD Aluma Star NEW never had tires mounted or drilled 15"x12"x4" Back space and 4/34 Bolt pattern-needs a little buffing from sitting around---$300.00 1---each---WELD Aluma Star NEW same info as above but 3 inch back space--$300.00 ONE pair Mopar P7 heads as from Mopar need finishing---$375.00 used set of JESEL rocker arms shafts ,mounts,bolts etc for P7 heads may fit other makes of heads---$500.00 1--Each-- Chapman ported Mopar W7 head cost over $2300 new---make me a reasonable offer!!!! PM me for contact info or more info regarding parts----Shipping will be by UPS GROUND from Zip code 60047 Dick Ullrich FED 387 |
