Old 06-06-2012, 09:17 AM   #1
Jmurphy1333
Default 85 S10 S/ST,SG, Foot Brake,Bracket, 8.50 you choose
Also available for $11,000 with No electronics
Above Added: Mon May 14, 2012, 8:18 pm EST
85 Chevy S10 Round tube back halved by Wild Rides located in NJ WWW.WildRidesRacecars.com
This Car is a real Money Maker has won every type of racing from Big Dollar Foot Brake races to Super Pro to NHRA Super Street hate to see it go but I have a new project in mind
Chassis:
Chromoly Round tube Back half
4 Link with Anti Roll bar
Fab 9 Rear strange Center section Spool and axles
Wilwood Brakes on all 4 Wheels
Has 14X32W on Rear Hoosier Fronts On weld Aluma stars
Lowered spindles, Moroso trick springs Qa1 adjustable fronts
QA1 rear adjustable Coil overs
Set up with Motor plate for Small block Chevy and Powerglide
Dual battery Mounts with 2 Yellow top Optimas
5 Gal Fuel Cell with all Black Braided Lines and Fittings -12 to filter -10 to front with -8 return line
-4 Trans lines all match
Body:
Body work and Paint done At Thriftway auto Body
WWW.ThriftwayAutobody.com can be seen in customers section
Quarters stretched to accomodate Changing big Tires
Cowl Hood
Bed is finished inside stock bed floor completely removed and done beautifully in Sheet metal and tinned on top painted Silver with a removable section to access batteries and fuel Cell also has access flap to fuel between rounds
Interior:
Stock floor replaced with Sheetmetl and Extra Large tunnel for Trans Clearance
2 Kirkey Seats with Covers
Hurts Quarter stick with elec shift Solenoid
5Pt Harness
Removable Window net
8.50 Cert Cage cert expired with drivers side swing out Bar
Carpeted interior with Custom dash
Electronics:
MSD digital 7 Programable
Biondo mega Switch Panel with circuit Board
Biondo Elec shift controller
Biondo mega 450 with custom removable mount wired with weather pack connectors
2 Biondo Double 0 Buttons in grant tilt wheel
http://http://www.racingjunk.com/Spo...half-S10-.html
Jmurphy1333 is offline   Reply With Quote
