Old 11-29-2011, 08:51 PM   #1
pro318
Default neck collar
Do you still have to use a neck collar if you use a head and neck restraint ex. hutchens device??
pro318 is offline   Reply With Quote
Old 11-29-2011, 08:55 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: neck collar
NO but it is optional not mandatory---ya need one or the other but check the class rules some classes HANS is MANDATORY
Old 11-29-2011, 09:36 PM   #3
pro318
ok thanks. would be running s/gas
Old 11-30-2011, 12:27 AM   #4
voltdr
Liked 100 Times in 51 Posts
If you use a HANS device, you will still need the neck collar, OR a head sock, OR a skirted helmet. It is in the 2012 rules amendments.
voltdr is offline   Reply With Quote
Old 11-30-2011, 12:49 AM   #5
FED 387
WRONG WRONG!!!!!--- go back and read the rules amendments for 2012 EITHER collar or HANS -- however some classes /some types of vehicles(open/closed) some ET's Some MPH a HANS is required in lieu of a donut-----read it closely!!!!!
Old 11-30-2011, 01:51 PM   #6
Dave Steltz
Dave Steltz's Avatar
If I remember correctly, the mfg'rs of the Hans and Safety Solutions units ( I have the pro-rage) tell you to NOT wear a neck collar with a restraint, it will interfere with proper fit and operation...I know with the rage, I dont see how I could wear the collar and not have it mess with the teathers and release strings...
Also if you wear a restraint, you must have a head sock or helmet skirt...
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 11-30-2011, 03:33 PM   #7
FED 387
Question Re: neck collar
the only places I see a skirt or sock required here is for FRONT ENGINE or Supercharged or turbocharged vehicles or in some instances Nitrous cars---be damned if I can find where in the 2012 rule book OR 2012 amendments that with a HANS you MUST use a sock or skirt---please enlighten me where does it say that--I looked thru the rule book for over an hour and I do not see that anywhere---not talking about any Alcohol or Nitro classes either--thanx Comp
Old 11-30-2011, 04:31 PM   #8
voltdr
I just received an email from NHRA tech, Pat Cvengros, You do not need the neck collar BUT you will need the head sock or skirted helmet.
Here is the email content.
If I decide to use a HANS type device, (not a class requirement) while racing in SG and/or SC.
1. Do I still have to use a neck collar?
2. If no neck collar, do I have to use a head sock or shirted helmet?
Thanks,
Dan Foley
No you would not be required to use a neck collar if you used a head and neck restraint system. You would however need a head sock or skirted helmet.
Pat Cvengros
Old 11-30-2011, 06:55 PM   #9
FED 387
You're right finally found it it is under the PROTECTIVE CLOTHING section not in the helmet or neck collar restraint area---
Old 11-30-2011, 08:02 PM   #10
Bill Baer
I wear a HANS with a helmet skirt.
