I have a 1972 camaro back half car stock front end. I have a Dart lil M block with a Milodon 30908 oil pan. The Hedman hustlers are Very close on the starter side. I am wondering if anyone has this same setup?? and has done a diaper? What did you use? How much more did it cost to get modified? From what I have been seing most need to be modified ?
![]() 100_2101.jpg by looker_57, on Flickr ![]() 100_2097.jpg by looker_57, on Flickr ![]() 100_2101.jpg by looker_57, on Flickr Last edited by looker_57; 12-17-2011 at 09:57 AM. |
Contact Dennis at DRE, he can make whatever you need.
Kevin T |
Liked 21 Times in 6 Posts
No problem Looker we can get you fixed up call me 217-454-5289
so even with my clearance around the starter and header tube being about jean thickness,thats with the mini starter, you can work around that? I tried to call the number best time to call I assume would be monday?
Yes call Monday please No problem to fit we go behind stater
My dad has a 72 camaro with a big block. DRE made us a diaper to fit with no problem. Even made provisions for going around the stock motor mounts
