Old 06-28-2011, 09:14 AM   #1
bighead
bighead's Avatar
Default Circus motorsports engine raffle
The following engine will be raffled during the upcoming 2011 Circus Motorsports Greg Morris Memorial Golf Tournament to be held Sept. 21, 2011. If you want to purchase a chance please call Tammy @ 972-937-4336 or email me with your contact information to raclown@aol.com. The tickets are $100.00 each and 300 will be sold.
615 12 Degree Pro Series Racing Engine
1236 HP @ 7400 RPM, 945 FT LBS @ 6200 RPM
Block - Dart Big "M" Sportsman 10.200" Deck, .903" Lifter Bore Sleeves
Crankshaft – Callies Magnum 4.625" Stroke
Rods - Callies Ultra 6.750"
Pistons - Diamond Custom for Brodix 12 Degree
Bearings - Clevite "H" Series
Rings - Total Seal File Fit Moly
Timing Set - Belt Drive System
Balancer - ATI 7" Internal Balance SFI
Flexplate - 168 Tooth Internal Balance SFI
Cam - Comp Cams Mechanical Roller
Lifters - Crower Severe Duty .903”
Pushrods – Manton Custom 7/16"
Rocker Arms - T&D Shaft Mounted Design
Oil Pump - Moroso Billet HV/ HP
Oil Pan - Moroso Double Kickout Steel
Cylinder Heads - Brodix 12° CNC with 2.520"/ 1.860" Titanium Valves, Titanium Retainers, and PAC Triple Springs
Intake Manifold - Brodix PM1917 "Big Mouth"
Carburetor - Sunset Dyno Tuned 1150 Dominator
Ignition - MSD Distributor, Crank Trigger, and Moroso Wires
Evacuation System - Moroso 4 Vane Pump
Bighead
bighead is offline   Reply With Quote
