OK, if we decide to pursue this 1994 Lincoln, some questions here. These newer cars are a brave new world to me. I know you can do the usual things, unhook things that aren't needed like the AC,air pumps and such. What else can I do? For NHRA stock, can I change things like MAF or MAPP sensors (forgive me I at present don't know what all this car has). What about fuel injectors, do they have to be stock or can these be changed out?
What about running these cars with open headers, do you need to weld bungs onto the downpipes for O2 sensors? Or can these be eliminated altogether? I know I'm going to need some kind of controler and a laptop, the computer I have, the controler we are already looking at. I also know, if we can get thing to run competitively. I'll need some way to do a fuel check. How do I set this up? This is just a start. Something else, I haven't been a member of NHRA since about 1989. What's it cost to join now, about $70 or so? I imagine a competition number is about the same?
Robert Swartz - Swartz & Lane 66 Chevy II Pro 95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock |
Liked 100 Times in 45 Posts
Robert,save your money and your sanity by just putting down the keyboard and stepping back slowly.
Seriously,why would you throw your money down a rat hole with an unproven quantity at a time when the economy is so bad none of us may be racing in a few years.
Former NHRA #1945 Former IHRA #1945 T/SA |
#3 | |
Liked 53 Times in 25 Posts
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
Don't spend your $$$$$$$$$$$ on the NHRA stuff until you're sure it is a viable combination. Run T&T's to figure it out. Eddie may sound a little rough but he makes a good point. This isn't your NHRA of old.
Now for the car. Loose all of the exhaust after the H-pipe. Get a wireing diagram and see if you can drop in an ecu from a mustang gt of the same year. Put at least a 4:10 gear in it and if you're not within1.2 to .8 of the index. take it to the crusher and use the money for the enjoyable beverage of your choice. Oh by the way, find you a mod motor in a u-pull it wrecking yard and spend the day/week/month just taking it apart. No one watches what your doing or even if your buying anything from it and it will give you an idea of weather you want to wrestle that bear. One last thing check the intake manifold. These were plastic and prone to breaking. Last edited by Larry Munk; 08-18-2011 at 07:31 PM. Reason: added intake |
I made my post with humor in mind.And with the intent of seeing Robert not waste money on an unknown quantity.
Just not really sure why anyone would want to talk Robert out of building his Hot Rod Lincoln. I guess since it's not a 68 Camaro or a DP or CJ, it won't work. 2/3 of the class cars out there would never have come to be if someone didn't take a chance. This car is as unique a Gremlin or a Caddy or a 4 door Nova or a 9 passenger Caprice wagon. No reason why in should not work, it's just a long wheelbase 5.0 Mustang.
Good luck with that project Robert. |
