Liked 308 Times in 103 Posts
Your Granny is offened by the term "Granny Shift"
If your left leg and right arm are noticably larger When you you were a kid your bicycle had 3 pedals Your 4 year old has to use shifting motion to count to 4 Thought about a career truck driving just so you could shift gears Your wife says your 6 year old lost a tooth you reply which gear You use 4 speed for bench pressing You quit your job because company car was automatic Refuse to have automatic withdraws on checking account Hear someone Granny shift and you have to be restrained You have ever got a christmas card from the Nashes,Liberty's,Long's,or Hemmingson's Ever launched a footbrake car on top bulb Your baby gets upper& lower teeth and you try to figure what ratio they have You never have heard a opponent's car leave the strarting line Mike Taylor 3601 Thought of something else new stick trans X$'s, new clutch setup X$'s,new shifterX$'s ,the fun of driving a stick,PRICELESS |
You Bet! X2
Sean Fischer ![]() |
Liked 68 Times in 26 Posts
can relate to that, thks,
Ditto
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
Liked 2 Times in 2 Posts
I like it!
Real Racecars Have 3 Pedals!!! ![]()
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
[QUOTE=Mike Taylor 3601;275063
If your left leg and right arm are noticably larger That only applies to the "old school" 3000 lb + pressure plates. I have McLeod Soft Loks in both cars, and the gas pedal is harder to push down than the clutch! (Maybe a slight exageration, but not by much.) You use 4 speed for bench pressing Yeah, but a Jerico doen`t give you the same "workout" that a all iron Toploader or MoPar A833 did! Mike Taylor 3601 Thought of something else new stick trans X$'s, new clutch setup X$'s,new shifterX$'s ,the fun of driving a stick,PRICELESS[/QUOTE] Hers a couple more; you don`t own any pink T shirts. You also don`t own one of those wierd looking funnels that is really skinny at the bottom, You can buy a used Jerico, run it for 5 or 10 years, with just a few oil changes, and sell it for what you paid for it. Did ya ever notice that stick guys tend to smile more?
Banned
Liked 235 Times in 110 Posts
Liked 602 Times in 138 Posts
Some of your most valued possessions are your never worn "Indy Qualifier" T shirts from Liberty.
"Did ya ever notice that stick guys tend to smile more?"
That's a fact !!!! |
Liked 783 Times in 195 Posts
Here's a couple more:
Everytime you work on a friend's automatic racer, you slow it down. You drive your wife's automatic car using your left foot for the brake simply because it won't be still. Converters make no sense; if you need to leave harder, just step it up. You know the gear ratios of every available Detroit V8 manual transmission built since 1955. |
