Old 06-22-2011, 11:29 AM   #1
chase williams
Liked 6 Times in 2 Posts
Default Comp / Super Stock Parts Sale
Parts Sale
Rear Gears
Richmond 9” 5.43 Ring & Pinion (was set up but never run) $300
MW/Richmond 9.5” 5.33 Ring & Pinion has been lightened and surface enhanced. Comes with M/W yoke, Driveshaft magnet ring, Pinion support, and aluminum spool with bearings LOW runs $750
Tires
1 pair Goodyear 2121 tires (2 runs) $350
1 pair Goodyear D2200 tires 33.5x17x16 $200
1 pair M/T radials 33x14.5x15 $150
Wheels
1 pair Weld Double Bead Lock Wheels 16x16, 5” back spacing, 5 on 4.75” bolt pattern LIKE NEW! $1600
1 pair Weld Double Bead Lock Wheels (Reds Conversion) 15x15, 6” back spacing, 5 on 4.75” bolt pattern $600
Drive shafts
PST Carbon Fiber drive shaft 50.5” Joint-Joint, SFI spec 43.1 w/ Strange yoke P/N U1666 $450
Engine Parts
David Cook Dominator Carburetors like new 2.060 bore 1.750 venturi $2000
CFE wedge Intake (chevy) 2x4 top 8.200 deck $375
1 set Manley Nex Tek valve springs 1.500” double springs (new) $300
CSR water pump, fits short deck or big block (used) $150
1 set (8) MGP Aluminum rods Model: SB1500, .990 pin, C/D 5.445”, H/B diameter 2.0150”, B.E.W. .9410, S.E.W. 1.150/1.150 (8 runs) $300
For more information
Email: chasewilliamsracing@hotmail.com
(903)692-2150 (Chase)
chase williams is offline   Reply With Quote
