Old 04-07-2011, 12:27 PM   #1
RJ Sledge
Liked 294 Times in 93 Posts
Default Ford and Mopar Aluminum R/E Cases??
Looks like the new Mustangs and all Mopars and GM Stockers are the only ones to get to run the aluminum 3d member cases. If you have an older Ford car you can't run an aluminum 3d member, regardless of what is said in the rule book of the last several years. It was legal in 2008 to present, now its illegal. If you have a 2008 Mustang and up Stocker you are ok, but not 2007 and down. If you have a Mopar new or old you are ok as is the 12 bolt aluminum cover for GM.
NHRA in all their infinite wisdom has decided that a 4 year old rule is now not legal if you have an older Ford Stocker.
Really makes sense don't you think?
RJ
RJ Sledge is offline   Reply With Quote
