Liked 205 Times in 93 Posts
anyone know a ford or aftermarket part number for the SBF oil pump relief spring cup? i've replaced the factory spring with a stiffer unit but can't find the proper sized cup that retaines it...
Liked 230 Times in 75 Posts
This is the pump I run did alot of research. Melling 10687 has a threaded plug for the relief spring it also has support on on both sides of the gears shaft. Nice pump compared to what else is out there got mine from summit for about $50.
Banned
Is it a gear pump or G Rotor?
10/4 on the 10687 west coast. thankyou. (motor is a 302ci) i just have this mellings std. volume gear type pump new on the shelf and i'd like to move it...canton lists a higher pressure spring and the required type plug, they say it's a '69/'70 boss 302 plug. sometimes the simplest things turns into an aggravating situation....
part # C20Z6A616A... 21/32" OD...NLA from ford.
Blueoval Ralph it is a gearotor pump this one is a standard volume they do also make them in high volume.
