Old 05-28-2007, 09:18 PM   #1
SST159
Liked 20 Times in 16 Posts
Default Oil pressure problems
Anyone out there ever experience oil pressure dropping to about 10 lbs just after the car passes the 330 ft?
I am out of ideas.
Once the pressure drops, I lift and it will recover right away and I can finish the run with 60 lbs pressure.
Oil pressure is 40 lbs hot at idle no problem
After I saw this I pulled the motor, changed the pump and pickup, went back to the track made a pass and the same thing happened.
I added a qt oil, same thing, added another qt. same thing.
7 qt pan and I usually run 6 qts. ( one in the filter)
Changed the guage, same thing happens.
SBC with moroso eliminator pan 8 1/4" sump. using a Melling pump and pickup.
Any ideas out there?
Drew
S/ST 159
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
