Old 02-20-2010, 12:40 PM   #1
Bruno 3776
Bruno 3776's Avatar
Default NHRA Stock/Super Stock Classification
Can someone help me to understand how to read the classification guide? To determine the weight break, do I look at the year of the car with the size of the intended engine in the same year?
My intended combo is for Super Stock.
  • 1982 Mustang hatchback
  • 1968 302, 4 barrel engine
  • Automatic engine
Thanks for the info.
Ronnie Dozier
Bruno 3776 is offline   Reply With Quote
Old 02-20-2010, 01:18 PM   #2
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Default Re: NHRA Stock/Super Stock Classification
Based on the Classification, a 3 door `982 Mustang has a shipping weight of anywhere from 2,555 to 2,582 (depending on base model, GT, GLX or GL body). There are two, 1968 Ford 302's listed. One is a 210 HP NHRA rated, one is a 230 HP NHRA (de-rated to 200 with OEM heads or 230 with Replacement Heads). Using the 210 version, in the GLX body, the weight break is 12.29, making it a natural GT/I or GT/IA, and is permitted to also run GT/H(A) and GT/J(A).
http://www.nhra.net/tech_specs/class...s/1968FORD.xls
http://www.nhra.net/tech_specs/class...s/1982FORD.xls
Old 02-20-2010, 03:55 PM   #3
Bruno 3776
Bruno 3776's Avatar
Mike: thanks for the explanation.
One other question, how do I determine which HP rated 302 I would be using?
Ronnie Dozier
Old 02-20-2010, 04:40 PM   #4
David Ley
David Ley's Avatar
Send a message via AIM to David Ley
210 hp is a 2 bbl. combination
230 hp is the 4 bbl.
Dave Ley
NHRA TECH
David Ley is offline   Reply With Quote
Old 02-20-2010, 05:10 PM   #5
Bruno 3776
Bruno 3776's Avatar
So if my heads show the casting of 2V - C8OE-J and based off of the NHRA blueprint guide, these are for the 210 HP combination. I'm assuming that means I couldn't use them on a 4 bbl 230 HP combination, correct?
Mike also pointed out that the 230 HP combination is with "replacement heads" and defactored with a OEM heads. I don't see a specific replacement head listed for the 1968 302. Any ideas about how to find out what that replacement head is?
Ronnie Dozier
Old 02-20-2010, 05:36 PM   #6
David Ley
David Ley's Avatar
All the information you need is in the Classification Guide and the Engine Blueprint lists. If you look at the top of the 68 Ford Class Guide ( GT Specs) it shows the different HP ratings for the different heads. When you go to the specific car in the Class Guide ( 68Mustang ) it shows the replacement heads. In your case Canfield or AFR. Now if you are really serious about this combo you can claim it as a 68 Mercury 302 and you get to use a Holley carb.
Dave Ley
NHRA TECH
Old 02-20-2010, 10:27 PM   #7
Mike Carr
Mike Carr's Avatar
I typed the wrong info earlier. The 230 HP 4 bbl motor is NHRA-rated at 220 with OEM heads and 230 with replacement head. I incorrectly wrote 200 earlier with OEM heads.
Old 02-21-2010, 11:29 AM   #8
Bill Harris
Liked 26 Times in 13 Posts
Bruno, the C8OE-J heads are the 2BBL heads and have a larger combustion chamber than the 4BBL heads. The 4BBL engine was 10:1 while the 2BBL was 9:1 which is why the chambers are larger. So, no, you can't use them on the 302/230 engine in S/S. The right heads are either C7OE-C or C8OE-F.
There are two aftermarket heads approved for the engine. One is a AFR #1299/165 and the other is an Canfield #18350. The S/S HP using the aftermarket heads is 230 while it it 220 if using the Ford heads.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 02-21-2010, 07:27 PM   #9
Jeff Lee
Jeff Lee's Avatar
I'm with Terry and I've looked at this as a GT / SS option for a Maverick. Go with the 1968 Mercury 302. Class break down is the same as the '68 Ford 302 4bbl
Jeff Lee 7494 D/S '70 AMX
Old 12-01-2010, 10:03 PM   #10
Wisman Racing
Wisman Racing's Avatar
Liked 4 Times in 2 Posts
I am putting my '69 Camaro into super stock next year. I just need to know if IHRA's horsepower factor is the same as nhra's, and if I were to goto super stock production how do i find a combination to use?
Wisman Racing is offline   Reply With Quote
