Mayday-----I have gone through 15 opti-sparks,bought the new so call billet MSD and still I blow them constantly.I am told that someone has figured out how to make them last.Who and how please I need help in a hurray.
Paul Cambria
BS/A,A/FIA 00 Camaro- CS/A, B/FIA 94 Camaro .2012 copo 4.0 |
Liked 334 Times in 181 Posts
Go to Corvettefever.com website look for Opti-spark under HOW TO section gives a detailed step x step with pictures way to solve any problems with these units... Hope this helps , it solved mine on my Bro in laws street car---Comp 387
Also go to GMhightechperformance.com this site tells you about the 3 versions of the opti spark how they work what makes them malfunction, trouble shooting symptoms and how to correct any problems, caused by the LT-1 opti spark ignition system failures too. I am sure with both of these sites you will be able to see and figure out your problems and hopefully correct them too. Comp 387
Guest
Posts: n/a
woodro has always done mine-never had a problem biggg
YOU CAN'T PUT A PRICE ON A GOOD TIME |
#5 | |
Paul, most are caused by the rotor retaining screws coming loose, or the metal blades coming off the rotor. Red locktite is how I fix the screws on mine, and aliminium pop rivets to hold the blades on instead of the plastic pegs they are mounted on. Too much cam end play, or too long dowel pin in the end of the cam causes havock also. Had one (rotor) come apart Sat in mine, but hadn't riveted the rotor together. Had a riveted one in the tool box, but not the car. Don't claim to be bright. I just use an original GM unit in mine. Avoid an Opti from Autozone, etc. Be interesting to hear what (if anything) Woodro says about this.
Ed Wright 4156 SS/JA |
Liked 5 Times in 3 Posts
Call Steve Hanby 503-931-6224 he has the fix! Problem solved.
"Go With Confidence" |
Guest
Posts: n/a
Paul are you using a crank trigger and just using the optispark to fire the plugs?
woodro josey I miss Buster Couch and Lex Dudas. |
Just the Optispark
Paul Cambria
Liked 10 Times in 7 Posts
Paul go to Dynatech engineering, they sell a billet opti-spark that is great a little pricey but install it and forget it.
