Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 01-29-2010, 01:07 PM   #1
rod
Liked 20 Times in 15 Posts
Default milling choke/cfm change
what kind of cfm change can i expect by milling the choke horn off of a 650 DP holley?
thanks rod
rod is offline   Reply With Quote
Old 01-30-2010, 07:46 AM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: milling choke/cfm change
Well I,m certainly not a carb expert but I,m quite sure you wont change the CFM one bit by milling off the choke horn, you will however change the way the air enters the carb. Joe
Joe Buchanan SS/BX 3117
Old 02-10-2010, 06:38 PM   #3
Bill Baer
Rod
From what I have read it's not much (2-3 CFM).
However I have read and experienced that a K&N stub stack will help pick up the air flow of any carb especially if you machine it to fit inside a conventional velocity stack.
Note the K&N stub stack does not require any machining,it's a bolt on and will help all by it's self.
Hope this helps
