Old 01-01-2010, 11:51 AM   #1
T Ames
T Ames's Avatar
Liked 125 Times in 33 Posts
Default Mopar Stocker (small block A body) Parts Wanted
Returning after a number of years off and require updated components in several areas. Please send pm or email tmames@yahoo.com if you have any of the following available:
  1. ATI super damper for small block mopar
  2. Magnafuel pump/filter/regulator etc. (ProStar 500 or QuickStar 300/275).
  3. Stahl headers for small block A-body (1 7/8 primaries)
  4. 8 ¾ Pro Gear 5:13 or 5:38 (any left out there??)
  5. Complete Dana 60. Ideally 55.5” track, 43” between spring perches, aftermarket spool/axles, and a partridge in a pear tree.
  6. Jerico DR-4 with shifter.
  7. MSD chips 7-8K range.
  8. Wilwood Mopar A-body disc brake conversion
Thank you!
T Ames is offline   Reply With Quote
Old 01-01-2010, 10:46 PM   #2
Philip Saran
Liked 14 Times in 11 Posts
Default Re: Mopar Stocker (small block A body) Parts Wanted
You might want to do some shopping over at www.moparts.com
and also on www.racingjunk.com
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
