Liked 252 Times in 46 Posts
454 Block Completely machined, sleeved lifter bores, bored 060 over, needs only hone and cambearings to assemble 650.00, 2 Turbo 350 Transmissions, 252 and 275, Turbo Flite both freshened with few runs on each, 550.00 for 275 and 450.00 for 252, Dynamic/ATI converter small block 5200 flash Works great 350.00, #8201 MSD Pro Power Coil Brand new 75.00, 2 pairs QA-1 Front Shocks 67-69 Camaro, Brand New #RC 1914P Single Adjustable 150.00 Per Pair, 2 Lakewood Bellhousings and Engine plates, one has inspection cover and one does not, 200.00 each, AVO 12-way rear adjustable shocks for 67-69 Camaro used but work fine 125.00 /pair,MSD RPM module kit#8746 6000 series brand new 35.00, 2 sets Moroso Wheel Studs long 7/16" 10.00/set, Hopkins Brake controller Brand New Reliance #47285 40.00, Hopkins Brake controller Impulse Brand New #47235 digital 50.00, Big Block HD Short Style water pump Brand New 75.00, Crane Engine control box, needs to be repaired 75.00, Mallory 400 Big Fuel Pump, just rebuilt with all new internals 100.00, 3 L-88 Original Intake Manifolds,All make power call for dates, 400.00 each, 68-69 Tri Power Manifold Perfect Shape, 800.00 FIRM, T56 Tremac Viper 6 Speed Brand New, 308 first,was under 18" of water and seized up Original cost 2900.00 sell for 1000.00 FIRM. Contact Joe, ASA1070@aol.com, cell 201-755-8167.
Liked 804 Times in 168 Posts
What is the casting number on the tri power manifold ?
Thanks, Dave
Dave Casey 1330 STK |
Dave, I will look at it tonight and let you know. PS it,s a 435 HP. I neglected to state that in the ad. Thanks Joe.
Dear Dave, the part number for the Manifold is 3937797 dtd. 9/10/69. It was on the original car for 400 miles ,then taken off and shelved for 35 years. Thanks Joe.
Thanks Joe, I am looking for a spare for my 400 combo, 3937795, heck, only 2 numbers off
Thanks for checking, Dave
