Old 09-19-2009, 10:11 AM   #1
RJ
Default 12 bolt R&P setup
I am putting in my ring and pinion this weekend, and need some direction from the 12 bolt stocker guys regarding setup? - I have a 3600 lb. car, 5.14 lightened 9310 pro gear with 50 passes on it, heavy duty caps, T/A cover, and will be using light synthetic lube. It's a stocker and I expect the 60ft.'s to be in the high 1.30's, looking for any setup info/advise (back lash, etc.) you can lend.
Thanks
RJ is offline   Reply With Quote
