Old 07-16-2009, 06:24 PM   #1
R&S Motorsports
Smile Electric Vacuum Pump?
Does anyone have any experience with a electric vacuum pump, I see there are many people making them now and I have even seen some that use a stock GM one any info would be helpful.
Thanks
R&S Motorsports is offline   Reply With Quote
Old 07-17-2009, 04:34 PM   #2
Michael Pliska
Default Re: Electric Vacuum Pump?
Is the GM one a pump meant for accessories on a diesel? I was thinking about trying to get a wreckign yard pump and modifying it. How much vacuum does a typical pump draw, and how much volume does it need to be capable of?
Thanks,
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
Old 07-17-2009, 08:11 PM   #3
R&S Motorsports
I think the stock GM one is from a S-10 diesel like a accessory pump but not 100% sure.
Old 07-28-2009, 10:41 PM   #4
voltdr
Liked 100 Times in 51 Posts
I would worry about the volume of the pump. If it makes enough vacuum to run accessories, will that be enough volume to evacuate a BBC or SBC type engine. Interesting question.
voltdr is offline   Reply With Quote
Old 07-29-2009, 10:35 AM   #5
Michael Pliska
I would bet that one for a light-medium duty diesel (like an F350) would have reasonable volume to keep up with braking needs. I may have to do some more digging. Does anyone know the volume and vacuum level specs on existing ones used in drag racing?
Thanks,
Old 08-24-2009, 11:29 AM   #6
fcffab
I put on on my small block. It pulls a steady 5". I only turn it on before going into the water, and turn it off after the lights because I'm not sure how much current it is using.
fcffab is offline   Reply With Quote
Old 09-09-2009, 08:43 PM   #7
66chevron
I used an electric EGR pump from a 90's Chevy LT1 as a vacuum pump. Never did measure the vacuum, but it seemed to perform as well as a header pan vac. However, I took it off because it got to be a pain. Had to be turned on before the burnout, then off after the pass because the constant vacuum would limit oil to the rings when it was needed at lower RPM.
66chevron is offline   Reply With Quote
