Old 08-24-2009, 01:35 PM   #1
SCOTT SST2871
Default Moroso ds2 tire bleeding air
I have a set of ds2 tires i bought in february from summitt.one of the tires is fine,the other has been leaking down after sitting in the trailer for a couple weeks.i put it in water today and its leaking air from the lettering on the sidewalls on both sides of the tire.i called moroso and they told me to call summitt,icalled summitt they told me to call moroso!! After some back and forth,moroso said if i send it to them they will look at it...has anybody had this problem,with the tires i mean!! It will go flat in 2 weeks
scott fifield
SCOTT SST2871 is offline   Reply With Quote
Old 08-24-2009, 02:07 PM   #2
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Lightbulb Re: Moroso ds2 tire bleeding air
I can give you one so you can have a matching pair.....I've managed to slow the leaking considerably thanks to the suggestion on this forum that a liberal application of dishwashing liquid on the inside of the tire was the secret.
Dave Turner
SS/GT #1153
