Old 01-06-2009, 05:30 PM   #1
zracer305
Default 305 Stocker Top End System
For Sale Stocker 305 Top End Heads, Cam, Carb, Manifold and Air Cleaner
Heads are casting 14014416 built by Gary Hettler at Eaton’s. Heads have been flowed for cfm, ports have been checked and runner volumes poured. Chambers have been cc’ed to the latest NHRA Specs. Competition Serdi valve job preformed. Pushrod holes have been opened to accept larger 3/8 pushrods. All surfaces have been milled and trued to specs. Everything that can be possibly done to stocker heads have been done to this set. Guaranteed to be NHRA legal as data from these heads have been sent to Bruce Bachelder for his Cylinder Head Database.
Heads Include:
- Manley Severe Duty intake and exhaust valves
- Bullet Cams springs (set at 400 lbs open pressure)
- Comp Retainers
- Comp Valve Locks
- Comp Vition Valve Seals
- Comp 3/8 Guide Plates
- ARP 3/8 12pt Perma Locs
- ARP 3/8 Rocker Arm Studs
- Crane Nitro Carb Steel Rockers 5:1 ratio
- Extra Set of Comp Bee-Hive Springs come with this setup (not installed)
- Pre and post flow data
- Aluminum Fabricated Valve Covers
Cam Includes:
- Bullet Racing Cam .403/.415 lifts 260/266 duration
- Bullet Springs (installed on heads)
- Cam card
Carburetor Includes:
- Deano’s Carburetors Quadrajet completely rebuilt by Dean Oliver.
- Carb was completely disassembled, resurfaced inside and out.
- Rebuild to Dean’s specs
- Figuroa 8AN fuel inlet fitting
- 8AN fuel line
- This is a high tech piece!!!
Manifold Includes:
- Aluminum High Rise Manifold part number 14014432
- Perfect condition all holes and threads are perfect
- No porting or machining has been done to manifold
Dual Snorkel Air Cleaner
- Stock 305 dual snorkel air cleaner for the 305 HO engine
3500.00 plus shipping
Please send me a PM if interested.
zracer305 is offline   Reply With Quote
