Old 02-16-2009, 12:11 PM   #1
Paul Hellenberg
Default HELP Polishing SS Headers
I am in the process of polishing SS headers. I would appreciate any advice or tips you could pass on.
Paul Hellenberg
3881 SS and STK
paul@hellenberg.us
Paul Hellenberg is offline   Reply With Quote
Old 02-16-2009, 04:00 PM   #2
ron mattson
Liked 69 Times in 32 Posts
Default Re: HELP Polishing SS Headers
3m makes a mandrel that holds 3 inch scotchbrite discs in various grits they work awesome,
you can mount it in a die grinder or small electric grinder. #07485,07513,07513 are the 3 grits i used.
ron mattson is offline   Reply With Quote
Old 02-16-2009, 05:01 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
The 3M pads will help in preparing the surface,but to achieve a good lustre, you'll need a woven cloth buff on a high speed mandrel,and some black emory, or brown or red polishing rouge. ....Eastwood has all the stuff you'll need ,except the ambition and energy that will be required. ....BTW different series of stainless polish differently as far as lustre and brightness. .....Tom
Old 02-16-2009, 05:37 PM   #4
ron mattson
tom is right if you want a serious chrome type finish you will need to use some type of rouge, the
3m discs will get you to a very fine satin finish with no surface defects. if you go over the welds with
a tig torch after this process it leaves a very cool blue weld at each joint that looks great just remember
to inner purge with argon or similar gas to keep the inside free of contamination..
Old 02-16-2009, 06:07 PM   #5
Paul Hellenberg
Tom and Ron
Thank you very much for your insight.
Paul
