Old 02-08-2009, 01:15 PM   #1
ken robinson
Liked 224 Times in 87 Posts
Default 67Camaro frontend alignment setting ?
What are some of you guys running as far as caster , camber , & toe settings ? What would you set it up to start with its a 67 camaro ? I also saw that Global west has listed an upper A arm mount . Which looks like its off set to lay help the tire in or out ? Longer upper ball joints give you more travel , but do they change the need for different settings ? I can remember someone setting the alignment up with a floor jack holding up the front end . To make the ride height the same as mid to top end track ride height . I don't think the 67 camaro has a understeer bump issue compaired to some other cars . Any info greatly appreciated ...................Ken R . stock#1262
