Old 01-23-2009, 02:44 PM   #1
csjta
Default Turbo 350 Fluid Capacity
Can someone give me a good starting point for a Turbo 350 with deep aluminum pan, this is a newly buiult trans and wanted to get an idea before startup. I use the Lokar dipstich which is a pain to read
Thanks
csjta is offline   Reply With Quote
Old 01-23-2009, 05:07 PM   #2
Joe DeMarzo
Liked 123 Times in 11 Posts
Default Re: Turbo 350 Fluid Capacity
8 quarts, start with 7 and check and recheck
Joe DeMarzo 1317 STK
Old 01-23-2009, 09:59 PM   #3
Kent Hanley
Heads up on the Lokar dipstick. I had problems reading mine as well until Trans man Jack Sepanik came over and use a piece of sand paper on it. This helped the fluid stick and I found it much easier to read. I also suggest you check the length of the dipstick by taking the pan down and making sure. I found mine was off a little.
Hope this helps
Kent
Kent Hanley is offline   Reply With Quote
