Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 02-04-2010, 05:47 AM   #1
bill dedman
Liked 6 Times in 4 Posts
Default Slant-6 solid roller lifter cams?
I'm trying to put together a turbocharged, high-boost (30+ psi) MoPar slant 6 as an experiment, in a 1964 Valiant , and was wondering if a solid roller-lifter cam and valve train is available. I am not looking to turn much over 6K with this engine; maybe 6.5K, max... but I want the kind of aggressive profile that only a roller can provide, AND to avoid ZDDP-related issues.
Any advice would be appreciated; I'm new at slant 6's....
Bill
bill dedman is offline   Reply With Quote
Old 02-04-2010, 09:04 AM   #2
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default Re: Slant-6 solid roller lifter cams?
Well....if there is something out there I dont know.
What I do know is we had LSM out of Michigan do us a custom cam, (custom as in they made the core billet too for our application) Some places REALLY still make custom cams, (as opposed to saying they do and really just grinding on someone elses core) When noone had gundrilled billets, or ANY cores for the 6.1 hemis, I was reffered to them I was told how awful the price was because of "RUSH" , Custom billet , etc.
Not true $700 in a 5 day turnaround on a custom core......seemed reasonable to me, I mean not a SB econo cam price but not outrageous either for a fast turnaround on something that because of the profile he couldnt use one of his already done cores for (that they make as well)
Call Steve Sr. Up there and see what he can do for you.....
If you want to talk to someone who has already done this pm me your number and Ill pass it on to him, Im going to see him tommorow. He can send you goodie pics of the car in progress he changing to a monster fan.....its really kinda silly big.
Cheers
Chris "drooze" Wertman is offline   Reply With Quote
Old 02-04-2010, 04:32 PM   #3
R Hastings
Go to slantsix.org They can answer any questions you might have.
R Hastings is offline   Reply With Quote
Old 02-05-2010, 07:04 AM   #4
bill dedman
Thanks! I'll give them a try.
Bill
Old 02-08-2010, 03:46 PM   #5
bill dedman
Well, it turns out that for at least two good reasons, nobody runs rollers in slant 6's:
1. They don't turn the 225's any rpm (6 grand, mostly) and they don't need high valve spring pressures for that, and you don't need rollers with reasonable valve spring pressures.
2. The valvetrain is light enough to warrant the use of weak valve springs (given the rpm) so nobody wipes cams....
3. And, because of that, nobody makes blanks for roller cams for these engines.
Case Closed!!!
Bill
