Old 08-06-2008, 01:09 PM   #1
Johnny U
Question msd ignition
A friend of mine has a new dragster and he has been fighting a top end miss/flutter all year. He has tried different carb jettings and different carbs to no avail. Question is has anybody had to lengthen the msd trigger wires beyond the six foot length that they give you. He thinks that this may be where his problem is as there is not much room in this dragster and the msd box is approx 12 feet away from the engine. Have anybody run into this concern.Thanks .
Johnny U is offline   Reply With Quote
Old 08-06-2008, 02:10 PM   #2
SlickVic
SlickVic's Avatar
Default Re: msd ignition
Check the black connectors. They go bad. I have replaced them on all of my cars, some friends cars, and this past weekend on a super comp dragster.
87 Cavalier, 92 Corvette, 72 Nova, 68 Firebird
SlickVic is offline   Reply With Quote
Old 08-06-2008, 02:11 PM   #3
Tim Irwin
Most dragsters are built with the ignition in front of the foot box. It's a good idea to use shielded cable for the pickup and coil primary wires or at least seperate them from everything else. RF can come from alternators, water pumps or fans.
Tim Irwin 3002 COMP
Tim Irwin is offline   Reply With Quote
Old 08-06-2008, 05:10 PM   #4
ChevyII
ChevyII's Avatar
Liked 2 Times in 2 Posts
John,
Has Steve got the problem solved yet? When I spoke to him on the phone Monday, he thought it might be the 7AL3 box.
Thanks,
Mike
ChevyII is offline   Reply With Quote
Old 08-06-2008, 06:21 PM   #5
nshivgator
I had a problem of the sort years ago! Sometime the car makes a lot of RF! You can run the crack trigger along the bottom rail and run the coil wire maybe on the top rail! Sometime if all your wires are to close together it can affect the signals causing RF. MSD told me to ground the coil(neg) coming from the coil to the frame
nshivgator is offline   Reply With Quote
Old 08-06-2008, 06:39 PM   #6
340Cuda
Liked 800 Times in 337 Posts
After we went to an MSD many years ago, our car will miss if the distributor cap is not vented well.
Bill
Old 08-07-2008, 01:32 AM   #7
Jeff Beckman
Jeff Beckman's Avatar
Send a message via AIM to Jeff Beckman
I have gone to this extent, shield from the crank trigger to the msd box. Run a ground wire soldered to the shield to a chassis ground. On the crank trigger pick up, use a screw clamp to secure shielding to the crank trigger pick up nut.
Jeff Beckman 318J ET, SG
318T SC
Jeff Beckman is offline   Reply With Quote
Old 08-07-2008, 12:44 PM   #8
SC1448
Cool Re: msd ignition
Try disconnecting the Tachometer (green wire) and see if that helps. Been there, done that.
-Don
SC1448 is offline   Reply With Quote
Old 08-07-2008, 02:34 PM   #9
Johnny U
Smile Re: msd ignition
No Mike, he has not fixed the problem yet but he ordered the shielded cable and is going to try that first. Thanks for the many replies.
Old 08-07-2008, 05:55 PM   #10
thewrench3
What spark plug gap are you running? Mine did that when the plugs were gapped too wide. Its something simple and easy to check.
thewrench3 is offline   Reply With Quote
