Old 07-16-2008, 09:29 AM   #1
Greg Barsamian
Liked 427 Times in 97 Posts
Default Small Air Compressors
Looking for suggestions to install an air compressor in the trailer to fill Nitrous bottles. Must maintain 115-125 psi. Any suggestions?
Thanks
Greg
Old 07-16-2008, 08:11 PM   #2
BillK
Liked 30 Times in 17 Posts
Default Re: Small Air Compressors
Greg,
We used to fill NOS bottles a while back and if I remember correctly the pump was a real air hog. The pressure is not really what matters, its the volume available at that pressure. The NOS pump manufacturer should be able to tell you what cfm it needs at a particular pressure. That will tell you which compressor you need, just get one that will pump more cfm than you need.
Bill Koustenis
BillK is offline   Reply With Quote
