Old 04-15-2008, 11:52 PM   #1
Stock1024
Default Eagle Cast Steel Cranks
Can anyone tell me if an Eagle cast steel replacement crank is an NHRA legal crank to use in a 88 Ford 5.0L fuelly motor? Thanks for the help.
Stock1024 is offline   Reply With Quote
Old 04-16-2008, 07:39 AM   #2
Default Re: Eagle Cast Steel Cranks
To the best of my knowledge, no aftermarket crankshafts are accepted for NHRA Stock Eliminator.
Old 04-16-2008, 08:53 AM   #3
SSDiv6
Use the OEM crank and send it to Bullet Cams to have it prepped. The OEM 5.0 crank is a good piece.
Old 04-16-2008, 03:46 PM   #4
Stephen & Horace Johnson
Liked 165 Times in 54 Posts
I totally agree!!!
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 04-16-2008, 08:15 PM   #5
crazyponcho
sonny bryant does amazing work with stock cranks, it will come back looking like a true race piece.
crazyponcho is offline   Reply With Quote
Old 04-17-2008, 01:52 AM   #6
SSDiv6
Originally Posted by Ed OBrien View Post
If it looks like a true race crank it 's not legal ! But who ever looks ? Have a nice day
What is a "true" race crank?
Old 04-17-2008, 04:11 PM   #7
crazyponcho
Sorry "true race" probably is a bad desrcription. Are crank just had to have stock journal sizes (no shelf cranks that did, 400m) any way the crank came back with profiled counter weights and drilled rod throws plus it was polished to also help with windage, it looked like a billet crank.
Old 04-17-2008, 04:50 PM   #8
SSDiv6
My question of a "true" race crank was a bit sarcastic since any crank used for racing is technically a race crank.
The question started as a Stock Eliminator crankshaft. The description of the crank you are giving is not legal in Stock. It is not legal either in the base Super Stock Eliminator, unless you are running in the Modified classes with a Comp Eliminator style engine.
Old 04-17-2008, 04:56 PM   #9
crazyponcho
That engine was built for the "engine masters" competition. My experience lies more in comp eliminator type engines, I am slowly working on a car for stock but moneys going every where else.
