1994 Firebird Formula LT1 Street/Strip 13.03 et
http://images.craigslist.org/00o0o_4...St_600x450.jpgClean, NO Rust.
Pearl White Paint. Clean Cloth Interior. Engine internals are stock. It has a MSD Optispark. 4L60E Auto Fresh Build (less than 1500 miles) with Corvette servo. 3200 stall Winners Choice torque converter. Long tube stainless headers & 3" y pipe with CAT delete. PCM has a fresh performance tune programmed in. 160 degree Thremostat. Factory wheels with BRAND NEW tires. Optional new JMS Star wheels, Fronts: 15 x 4 with 26" Front runners and Rears:15 x 8 with 26/10.5-15R M/T Pro Bracket Drag Radial slicks. New AC Delco battery, cables and starter. Has factory limited slip 3.23 rear. I put in an aftermarket transmission cross member with the driveshaft safety loop. The driveshaft also had new u-joints installed and balanced when the transmission was built. Best 60' time is 1.74 seconds. Best ET is 13.03 in the 1/4 mile. Clean and Clear Title. $4450 with factory rims. $5700 including Race wheels and tires. For pictures go to link: https://minneapolis.craigslist.org/w...605517976.html Text or Call 612-275-6123 Thank you for looking. |
