-   Stock and Super Stock Tech (https://classracer.com/classforum/forumdisplay.php?f=4)
-   -   Approved fuel for low compression stocker (https://classracer.com/classforum/showthread.php?t=70089)
jmoneyfoot 06-04-2018 11:24 PM
What would the best approved fuel be for a 9.5:1 dish piston 305 2bbl?
Dan Fahey 06-04-2018 11:47 PM
Re: Approved fuel for low compression stocker
Sunoco 260GTX at 98 octane.
Do not any of the others are lower.
Mepprecht 06-05-2018 12:57 AM
Most popular fuel is probably C11 in stock across the boards. That or c12.
GTX JOHN 06-05-2018 01:44 AM
X2 for C11 with that compression in our Stockers.
Steve Stickel 06-05-2018 09:20 AM
Dan
The Sunoco 260gtx is an unleaded fuel, similar to VP C-10, easier on the A/F wideband sensors esp for the late model and dual duty street/strip use cars, although most guys on here will use the leaded fuels (C-11, C12) etc. to extend valve train life and achieve higher octane ratings. Another issue is availability, a racers preferred fuel may not be sold at certain tracks... Thanks to MG raceway for posting this chart..
http://www.maplegroveraceway.com/wp-...-reference.pdf
RKelliher 06-05-2018 11:22 AM
Run c-11 in my 81 305 dish motor . run about 3 hun.faster that c-12
Dan Fahey 06-05-2018 11:33 AM
Originally Posted by Steve Stickel (Post 564593)
Dan
Yes 260GTX it is an unlead fuel and I like it !
I can find it and less expensive than C10.
RKelliher said that running C11 works better than C12.
How does is work that one Octane Fuel works better than another?
Dan
terry1 06-05-2018 12:35 PM
Consistently, on a dyno, my engine makes 1% more HP with C11,
compared to VP110 or Sunoco Standard.
Terry K
GTX JOHN 06-05-2018 01:57 PM
We also are faster with C11 than C12 in back to back testing
in our low compression Stockers!
Mike Pearson 06-05-2018 03:16 PM
C-11 was designed especially for low compression stock and super stock applications. Its not always readily available so you have to plan ahead and get that fuel ahead of time. C-12 is much more readily available and a bit cheaper. Not as fast in the low compression engines as the C-11 but runs very well. To get full advantage of the C-11 it takes a jet change as I remember. I run C-12 in my super stocker
