-   Race Parts: Classifieds (https://classracer.com/classforum/forumdisplay.php?f=12)
-   -   1966-69 396 & 427 Parts L78 & L71 (https://classracer.com/classforum/showthread.php?t=37725)
dlv4540 12-14-2011 08:37 AM
1966 3869942 427 4 bolt block stanard bore with original pistons & rods $4000
1967 3919840 heads rebuilt E-24-7 & F-7-7 ported wtih overiszed valves $2000
1967 3904391 single stock head rebuilt dated C-15-7 $1750
1967 3904391 heads both dated J-10-6 ported with oversized valves $1750
1967 3885069 aluminum intake 6-27-67 with center plenum cut out $300
1968 3919840 single stock head rebuilt dated E-8-8 with 1.88 valves $850
1968 3919840 heads L-21-7 & D-23-8 bare and ported with 1.88 valves $850
1968 3933163 aluminum intake 3-20-68 with small weld repair on topside $300
1969 3919840 heads rebuilt and stock with 2.25 intake valves modified only $1750
1969 3955272 396 4 bolt fresh 30 over with new cam bearings & freeze plugs $1750
6223 steel crankshaft standard balanced to new keith black 30 over 396 pistons mounted to stock GM rods $600
6223 steel crankshaft turned 20 under ready to go $300
1969 8 inch timing cover $150
1969 8 inch factory balancer $150
7/16 dimple rods $250
330-770-2517 for any questions or pictures needed. Can ship if you cannot pick up.
SSGN 12-14-2011 10:30 PM
Re: 1966-69 396 & 427 Parts L78 & L71
Please send pics of alum intake
car3@rogers.com
Kevin
