Old 10-20-2019, 12:17 PM   #1
Jim Hawkins
Liked 115 Times in 35 Posts
Default powerglide vs 3 speed
Anyone care to share there experience switching from a glide to a 3 speed in a sbc stocker? Performance? consistency? reliability?
New car to me needs lots of updating and currently has a glide in it. Not trying to set any records but would like to keep the glide plus I have lots of powerglides here for spares with different ratios.
66 Nova 327/275 combo.
Thanks
Jim Hawkins is offline   Reply With Quote
Old 10-20-2019, 01:13 PM   #2
MR DERBY CITY
Liked 7,912 Times in 1,515 Posts
Default Re: powerglide vs 3 speed
A lot of it DEPENDS on how good your PG is....some guys have picked up a tenth...get you a Mc Clay, Leo Glassbrenner, Tim Wudarczyk, , Sepanek, Arnett, metric trans .....
Old 10-20-2019, 03:16 PM   #3
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
I can't say for a stocker, but I replaced a pg with a Mcclay metric with 2.52gear in my 3430# 283 super stocker. PG had a 2.08. Looking at the data, we feel good for a tenth at first race. There is a little more when Im able to play with the shift points, launch rpm. Hope this helps.
Ed McLawhorn Jr. is offline   Reply With Quote
Old 10-20-2019, 04:05 PM   #4
J.R. Haddad
Liked 1,464 Times in 307 Posts
If your not trying to set any records, and you don't run into too many heads up runs, keep the glide. Ask Vic Penrod how he feels about running a glide vs. a 3 speed. You will be about 12-14 slower with the glide. J.R.
J.R. Haddad is online now   Reply With Quote
Old 10-20-2019, 04:37 PM   #5
Alan Nyhus
Liked 799 Times in 236 Posts
Jim, '68 Chevy II, 327-275 G/SA: I changed a darn good A-1 Powerglide (1.98) over to a Billy Lynn Metric 200 (2.74) and picked up .10 on the average, just trans-to-trans. Further convertor work netted some more gains.
Billy does a really nice 200. -Al
"That'll never work....."
Old 10-21-2019, 08:21 AM   #6
Pat6868
Liked 88 Times in 28 Posts
To those that said they lost about .1 - .15 with the glide, is this with using the same rear axle gear ratio with both trannys.?
Pat6868 is offline   Reply With Quote
Old 10-21-2019, 09:02 AM   #7
Mike Jones
Liked 684 Times in 289 Posts
3spd is 2.75 low gear, PG is 1.98
Old 10-21-2019, 09:53 AM   #8
HP HUNTER
Liked 372 Times in 129 Posts
Jim
In Denver and the conditions your likely to run in, I would think the metric would be considerably quicker.
Old 10-21-2019, 10:51 AM   #9
Alan Nyhus
No rear gear changes for me when I changed over.
For sake of example, the 'same' convertor with the 2.74/2.75 low gear in the Metric will make the convertor act 'tighter' on the flash than it was with the 'Glide.
Not that the convertors interchange because they don't. -Al
Old 10-21-2019, 05:34 PM   #10
Ed McLawhorn Jr.
No rear gear change for me when going to the metric. I did send converter to change splines from pg to turbo. While out, trans guy loosen converter to account for metric.
