Old 04-17-2019, 09:58 PM   #1
rx dealer
Liked 53 Times in 13 Posts
Default Copo LS 396 and 427 Ford FE Med. Riser
COPO LS 396 Super Stock Engine... NHRA rated at 390 HP.. New!! Dyno time only
Calies 4340 Crank..Calies steel 6.200 Rods. Coated.Mahle pistons..Total seal rings
LS3 heads by Gray Motorsport.....New Valves .. PSI springs...Edelbrock 2 piece timimg chain cover. MSD coil packs.
Jesel Rockers.. Cam Motion Solid roller..COPO Hi Ram intake. Meziere water pump..New starter and SFI flywheel 100% Complete and ready to race Built by Rob Wright
427 Ford FE. Engine 1967 Side Oiler block C7AE-A ..Lemans Crank and Rods, forged pistons,
Medium Riser heads C5AE- 6090 F with new Stainless Valves and springs
Comp Cam Roller Cam Kit # K33-782B,, Comp Cam Rocker Shaft #1046HD....Edelbrock Alum. water pump
1967 Shelby GT500 Dual Four barrel Intake C7ZX-9425-A with correct/original BJ and BK Holley Carbs
Shelby distributor, Air cleaner, and valve covers...Cobra Alum. oil pan..has Hayes Alum flywheel with Center Force clutch. very rare.Complete Engine...Much More
Hooker Coated Headers fits FE Engine For 67-70 Mustang
Coan T-350 XLT pt.# 131120.. 2.20 low with Trans. Brake Rev. Pattern, Trans sheild, Brand new still in Crate.
Call Luke 248-342-3117
rx dealer is offline   Reply With Quote
